I don't believe the thumb controls on the steering wheel have anything to do with the airbag. When you remove the airbag just make sure the plug for the controls are still plugged in.
If you are the adventurist type you could look up the vid on youtube on how to trigger the airbag to blow while it is off the car then gut it for weight then reattach it.
2008 E86 M coupe
