      09-02-2019, 08:03 AM   #502
lakefront
Drives: 2017 Macan GTS
Originally Posted by lsturbointeg View Post
you just paint it. any duct work will be painted. for the grills I gotta find something that allows the grills to be mounted floating
edit: I think I know what you mean by HVAC are you talking about the flexible duct work? mine are all aluminum pipes/cylinders if that's the correct word for them
If you are leaving the walls as is than that's all you can do with supply pipes. Just thought if you were framing the outside walls I would suggest running lines over to the walls and putting grilles down low (heat rises). Have seen a lot of folks complain about basements being too cold because the warm air comes out near the ceiling and just sits there.
