Originally Posted by dc_wright
Originally Posted by The HACK
DSC doesn't care whether or not you're squared up. It doesn't work that way.
^This^
The only thing that matters is the difference in the diameters of the tires. DSC is looking at the outputs from the wheel speed sensors and tire width is immaterial so long as the diameters are close.
I stand corrected it seems like the stock diameter is 27 all around so if your close to that then it should work good.
I see his diameters are quite different front 25.7 and rear 25.3 wouldn't be surprised if it drove ok but m track mode would improve it.
Ideally you want your diameters as close as stock as possible. I think this is definitely your current issue.
Change your tires make sure they are all 4 the same diameter or close.
Gone but not forgotten:
2007 E63 M6 SMG, 1999 996 Carrera Cab AT, 2007 & 2008 E90 335xi AT, 2011 E93 M3 DCT, 2X 2002 E46 M3 SMG & 6MT, 2016 F80 M3 DCT
