Originally Posted by Reborn_
Originally Posted by bimmer35
Just wanted to share an update from my recent experience:
1. This amazon cable works, there is a switch built in, set it all the way to the right. https://www.amazon.com/gp/product/B0...UTF8&psc=1
2. Use the Bimmergeek Coding Tools, it did everything i needed, including a working "Manipulation" profile for NCS Expert. Works on mac with VMWare Fusion - Windows 10
3. Basically dug through numerous threads just to find out how to deactivate all amber light regardless off headlight switch position, and to only function as turn signals. Just wanted to throw this out here as there were so many combinations around. This worked for me.
ECU Module: LSZ.C36
PIN_20_37_ALS_PO = Set to nicht_aktiv
SL_VO_ANSTEUERUNG = Set to nicht_aktiv
SIDEMARKER_US = Set to nicht_aktiv
Also managed to do M Dynamic Mode with just one change:
ECU Module: MK60
TDR = Set to Aktiv
Did a couple more, but the guide to them is easily available. Happy to share any specific ones if you reach out.
AMP Setting, Mirror Tilt in Reverse, Auto Unlock Doors when the engine is shut off.
If anyone has had success, please share!
Thanks OP for creating this thread.
Mandatory pic for being almost eggless! ��
Details added to the appropriate posts (1-3). Thank you for sharing!
The ones you listed, are you asking for help with those? I'd also like help for auto unlock doors when engine is shut off, and even lock doors automatically (haven't gotten that to work).
ECU Module: LSZ.C36
ECU Module: MK60
TDR = Set to Aktiv
Yes sorry I am not sure why that phrase asking for help went missing. I haven't been able to do those listed.
I can definitely help with auto lock. Basically you also need to code the key memory to auto lock. Will respond here with the specific modules shortly!
Thanks again for getting this started OP!
