Originally Posted by thielepr
Kind of hijacking but I was to make basically the same post. Looking for a square set of 18”. What’s the widest tire on stock suspension?
I’m thinking a 18x8.5 should be good enough for a 235 tire front on a 40 offset but then it would be a waste to run a 235 on the back.
More round-shouldered tires like RE71R in 245 fits in the front on stock suspension (RS4 ended up rubbing in same size and aspect). If you're spending the money on a square setup, I'd at least consider getting front camber plates so you can run 2-3 degrees of camber - can fit 255 upfront for a proper square setup + make the tires last longer on track.
