yes strokeZ the amp cant be removed or you'll have no radio reception.
your recommendation is probably the best one except iyou wouldnt need the line out converters. if you dont plan on running any of the speakers off of the headunit, then you def dont need the line out converters since the speakers would be connected directly from the new amp (along with the RCA's to the headunit). but even if you planned on running the stock speakers off of the headunit, you would have to run the wiring from the headunit to each speaker (this is how i ended up doing it).
