Originally Posted by mfanatic325
So Racing Brake only offer fronts? No rears?
They have rears. They're just not listed because they have the same problem as does Performance Friction. The way the fasteners are, if you use stock pad shape eventually the pads will grind into the rotor to hub fastener. Solution is to go with a shorter pad, but they decided not to offer that until they have a set of pads they can sell along with the rotors, and that hasn't happened yet.
But they have rear rotors. I test fitted a set and had to give it back due to the pad issues. If you call them you can actually order it if you acknowledge you understand that the OEM replacement pads are not compatible. I'm waiting for their new pad applications to be ready, since I've already got a set of Hawk DTC-60s in the OEM shape for the rear right now.
