What I do and it helps is to take a popcicle stick or the like and put you window cleaner on a micro fiber towel covering the stick on both sides, with the window down run the cloth between the rubber pieces that would be on both sides of the glass and clean the felt. It will take several passes to get it clean. Make sure to change areas of the towel and keep the cleaner on the towel. You only need to clean about 1/2 inch down to get the area that causes the issue. The more you clean from this area the less streaks you wll have.
