You can order them from the UK as a set. Make sure the set ordered is for non M version as the front springs are different on the M.
You would be better off ordering the B12 ( B12 is the Eibach Pro springs w/ Bilstien B8 shock) set which is cheaper than ordering springs and shocks separately.
I have this set up on an 3.0si and it lowered the car about a 1/2" to 3/4". Had to add a BMW 15mm rear rubber spring pad to level the car in the rear once the new springs were installed. The cars rides far better on this set up than factory. Very comfortable on highway and compliant in the mountains.
