Originally Posted by XMetal
Is it my eye or is the driver rear looked lower than the passenger rear?
Wouldn't be shocked if it is, usually they adjust the rear collars to corner balance because it's easier to access. Although you would have to assume with it CB'ed with my weight in the drivers side, once I'm out the driver's rear should raise up higher?
Will probably take a tape measure to it tomorrow to see.
