Originally Posted by DRedman45
I got everything to install the airbox before my buddy had a dyno opening so I went ahead got started installing the box.
I have run into two minor issues.
The stock crankcase vent hose doesn't reach so I'll be extending it with rubber hose which is my only hold up currently. The other option is buying a csl crankcase vent tube and removing the crankcase side connector to splice in the stock connector. This is normal but turner doesn't list anything as part of their kit so I assumed that the factory hose would work.
My other issue was the oil drain bung on the airbox had apparently come off in transport. I used a bit of jb weld to secure it.
Otherwise the install has been smooth sailing and fitment is spot on.
I'll get a few more pictures when I get finished up
Man, as much instal info as you could share would be very welcome.
I think this may be my first modification. I need that induction noise in my life.
