You commented in a thread that I posted on the Wiechers roll bar using Sparco EVOII seats and VAC Hardware - so you can see how that setup looks there.
I am also planning to move to a Halo seat and the Circuit II dimensions seem to be nearly identical to the EVOII. However, I think the ERGO - with removable head restraint tabs - might be too tall and is at least 30mm taller than the Circuit II. Just saw them both in person at NJMP last week and you can definitely see the size difference.
AriuSen has run a BRIDE halo and I think a Recaro Pro Racer HANS and may be able to comment on those.
Definitely go with Brey Krause hardware. So much easier to install compared to VAC or other similar types of mounting brackets with high quality.
2013 E92 M3 Competition 6MT Slick Top | AW / Fox Red |
2006 E86 M Coupe | Silver Gray / Imola | JRZ RSTWO | APR Aero | Sparco Seats/Belts | Weichers Cage
Gone: 2017 Audi Q7 | 2011 E93 328i 6MT | 2014 Audi A6 | 2010 VW CC 2.0T | 2011 G37 S Coupe 6MT | 2004 G35 Coupe | SW20 MR2 Widebody Turbo
