Did you end up going with the MRT Kit?
Bimmerworld also sells a roll center kit that has a weld on riser that is on the bottom of the kingpin / knuckle. The riser is sleeved into the control arm bearing.
But, it doesn't do anything for steering response, Just a Ground control ADJ bump steer kit is available for that.
