Originally Posted by Pheonix
By the look of the foam, there is no way that pressure washer pump out 2.6 GPM!
You appeared to have have invested a lot of money and effort into this so you should check and make sure you have the proper soap, mix-ratio and everything else.
Here is the Foam looks like from my new Active 2.0 which only specs at 2.0GPM
Pheonix Yeah, the pressure washer was pretty cheap from Amazon a while ago, hard to believe its really pushing out 2.6 gpm the manufacture is claiming. A nicer washer is on my wish list when I move out of my current apartment. But this one does the trick for now. Additionally, I'm using a cheap foam cannon with typical soap, not "snow" foam, so my foam certainly not as thick as it could be like your picture. What soap are you using?
