Originally Posted by dc_wright
When you replace the rear shocks in addition to the shock mounts, you'll probably need new bump stops. The original ones deteriorate over time and they're cheap so might as well replace them while you've got everything apart.
Thank you
2019 M2C Sunset Orange/Black (Ohlins/swift coilovers, Ground Control Camber Plates, Dinan Heat exchanger, BM3 ECU tune, CF mirror caps, diffuser and rear spoiler, Vorsteiner V-FF 101 Patina Bronze wheels)
