      09-02-2019, 08:08 AM   #503
bosstones
Drives: o_0
Originally Posted by lsturbointeg View Post
Wire runs will be painted as long as they're in romex sleeving. The can lights tho there a part inside that needs to be masked off according to my Electrician. I'll have to post a picture of that
All of my house wiring is in conduit so I'm not worried about that. I may do some romex out of laziness just to get some additional outlets w/o having to anchor 2x4's to the foundation walls (until I plan out how I want to finish the basement). Not too worried about romex and paint either, just the low voltage stuff.
However, I have Cat6, RG6, and other low voltage are coming in from different points and converging in certain areas. Knowing me, I'll want to re-arrange some of the wiring at some point so I'm not sure if the paint will flake off and leave a mess or if some of the chems in the paint will have an effect on the outer jackets (I have horrible luck lol). I was thinking of maybe a solid cable trough or something. It'd also help protect the cabling from unwanted interference although the blue Cat6 jacket would look cool against the black background.
Still, though, I'm interested in any lessons learned about tarping/masking that you run into. The job can get quite messy, quite quickly.
