Great writeup. I'm glad you were able to make use of the "E86 DSP_E85.C02 FSW_PSW coded to E85.TRC.txt" file I edited. I read in the file from my 2007 E86, edited all the values I thought should be changed from E86 to E85 and saved it. I don't know if it ended up identical to a factory coded E85 car. If would be great if someone could post a factory coded E85 DSP file so we could compare the one I edited to see if the 2 files are the same.
Also the DSP module version I have is a C02. I don't know if they used different model DSPs in these cars. If you don't have the same model module, I would not use the file in this post since I don't know what would happen to your DSP.
