      09-23-2021, 08:44 AM   #51
FigureItOut
Drives: BMW Z4 3.0i
Originally Posted by golfmanpat View Post
Do you still get the manual override option with the Mustang motor?
The mustang pump alternative does not include a manual bypass valve. Once you plumb the new pump in your top will either function or remain static, no manually wrestling it into place.
Because of this it's wise to have the top in partially open state when you do your initial function testing. This will give you a fighting chance to avoid getting it stuck in fully open or fully closed condition if you plumbed it up wrong.
