Originally Posted by Clearancediver
Did you check your fluid level?
I'd flush the clutch hydraulic system as one step in the diagnosis of the issue....after looking for leaks at connections.
^This
And/or air in the system, which could happen with low fluid.
If the fluid is low enough to introduce air in the system, I would sure track down the probable leak in the brake/clutch hydraulic system, because that's a safety issue. Brake fluid levels will drop a bit as pads wear, but it would be very unusual for the level to drop past the minimum point without a leak. Unless the fluid had only been filled to the minimum mark, we recently flushed, or new pads installed.
Brakes are nice to have
