Originally Posted by ANILE8
When it is time to change your disc's you can order the 380mm disc's. You would also need two different mounting brackets for the front callipers if you change disc size but that is not a big deal. Z.R. will sort you out.
Yeah, good point. I'm hoping I won't need to change disc for some time tho. I might consider some additional brake cooling at some point. Only if I can block the ducts during normal street driving tho. SBM cut out the stock front ducts for me but FYI, that made no difference at all to cooling in my opinion.
2006 IBlue BMW Z4 MC - ESS VT2-525 Supercharged, JRZ RS1 suspension (500#F, 600#R) with Vorshlag plates, ST Trophy BBK with CL R6E pads, KKS gated exhaust, TMS sway bars, RE rear camber arms, VT engine mounts, Recaro Pole Position (driver), APR GT wing, Street: Volk G2s and Potenza, Track: Volk TE37SLs and BFG R1s.
