      05-17-2021, 07:52 AM   #119
MKSixer
MKSixer's Avatar
34188
Drives: 2015 BMW i8, E63 M6, 328d
2016 M4 GTS (Allotted)  [0.00]
2013 BMW 328d  [0.00]
2007 BMW M6  [10.00]
2015 BMW i8  [10.00]
Originally Posted by Ngilbe36 View Post
Good question. So I guess I would need to dig into this much more and read the actual regulation to answer this more completely, but until then Ill give you this.
RBR seems to have created a feature that passes the test and provides and advantage in a sport where you are trying to outcompete against other teams by engineering things to the finest of margins.
VW created a specific cheat mechanism to allow the SAE/EPA testing to get a false result. This has negative impacts on the environment and the customers that bought these cars expecting something different. Ill add that I work in the auto-industry so I do understand the drive to also outcompete with your competition among other automakers.
So in my mind, they are different situations, but I understand how you are drawing comparisons.
Go and read the rule. Passing the test, which in inadequate, doesn't mean you are in compliance.
Their wing must remain rigid in relation to the sprung bodywork.
It does not, in situ.
This is a rules violation. The test doesn't matter.
Edit: This is perfectly congruent with VW. They designed a cheat to pass the emissions test but return to pollution mode at speed. RBR designed a wing to pass the static load test but flex at speed. Notice the similarities?
Several actors have played James Bond, Sean Connery IS James Bond...
Sir 7ewis, 7X FIA Formula One World Championship, World Driving Champion. 100 Wins. 101 Pole Positions. 54 Fastest Laps. Actual Rain Master. Leave me to it, Bono. One Race Win in each of his 15 years in F1. Most Laps Led in Formula One. The Centurion.
yco5758.50
