Originally Posted by JAS1169
Greeting's from the USA
Your top is currently down? yes/no
the red handle by-pass will not release the top. yes/no
Note: slightly pull out the red handle in your trunk and then twist the handle. Just pulling on the handle and then letting go.... does not engage the by-pass system. The red handle should be twisted about 90 degrees. There are video's on youtube on how to engage the red handle by pass.
you can hear the motor running both up/down yes/no
Please try resetting your windows & then try moving the top with the button in the car. Here's how to reset windows:
https://z4-forum.com/forum/viewtopic.php?t=196
Please get or simply have error codes read Your going to need a code reader on this
YES, I could do it with the red handle.
Yes, now the roof is completely down, but now is not closing / going up.
But also very strange, I can close / up the roof manually, only can move it a little up, but appears like stucked.
I hear the motor of the top of the roof is working but the one that close/open the roof I cant hear it. Is located in the side of the pilot right ?, almost in the trunk.
