Originally Posted by jns_e85
Originally Posted by ethan9273
This is what I saw after opening the caliper
All 4 pistons had some kind of corrosion on them. After cleaning up and installing it was better but not completely gone. Will I have to replace my rotors from damage after just getting them?
Use a brass wire brush to get as much off and reinstall. As long as rotors are still in spec thickness wise and are not deeply grooved, you should be good.
Re-bed your brakes following proper bed in procedures after reinstall and see how they feel. If you have a judder afterwards, may need to warranty the rotors
Man... wire brushes clean, re-bed... STILL there. Unbelievable .
