When you first changed rotors did you change the rotors and pads at the same time? Or did you do the rotors first and pads second? If so how many miles were put on the car between the rotor and pads replacement?
Have you confirmed the caliper guide bushing have free movement? Any corrosion?
07 Z4 M Coupe AW/IR
