Originally Posted by exdos
If you were to fit a pair of rectangular shaped shims with holes for the bolts between the car chassis and the brackets, when the brackets are fastened on tightly, this would provide reinforcement to the chassis without the need for welding.
for lasting protection against fatigue, imo welding a proper solution inplace is the only REAL solution and will safe guard this part of the car.
If your cars on stock bars (which i believe are thick enough imo) this isnt an issue, id rather tune the setup with a proper coilover and spring rate setup.
