I'm in the process of obtaining the DynaPack viewer files, so we have to be patient until those come in.
For now, here are some instructions on how to download the viewer program, and use its basic functions/features:
- Download and install the DynaPack Viewer.
- Run the DynaPack Viewer.
- Place the mouse over the <F8> key on the screen and left click.
- Press the "Import Files" button.
- Locate the file you downloaded and saved on your computer. Highlight it, and click "Add" then "OK"
- Select the "Vehicle Folder" on the left of your screen where you just imported the dyno results.
- When prompted to overwrite the current vehicle setup, select "YES"
- When the dyno chart is first displayed, you'll want to change a few settings (if they are not already set). Select Setup->System. Look under the "Power Correction Standard." Change the Standard to "SAE (adapted) setting.
- In the "Units" area, select your preferred HP/TQ, PS/KW/NM settings -- according to how prefer to view this data.
- Makes sure the "Correct Torque with Power Correction" checkbox is checked (bottom right of screen)
- Press the <F10> key, then hit -- "OK"
- Change the display: Display-->Flywheel Torque Graph.
- Look at the various other display graphs as well.
- Temperature Graph
- Statistics
- View Data. You can add/delete data columns on this display. You can also look at the individual data for each dyno run by changing the "Data source. You can also export the data from this screen into a spreadsheet.
- Play with the software and you'll probably prefer it to a spreadsheet.
- Export the data if you wish into a spreadsheet, and make your own graphs.
