Originally Posted by pokeybritches
Where is your MAF sensor located?
Factory location of the MAF is on top of the pipe leading from the filter box to the throttle body. Basically the first thing to disconnect when replacing the air filter.
The kit relocates it to the bottom of the ESS pipe leading to the throttle body. The kit was not designed for the E85 - lots of leftover and spare parts. There is plenty of room for improvement or custom fabrication work.
