Great thread. The procedure is simple and can be done without removing anything else in the engine bay. On my 2004 Z4 2.5 there is just one black wire, not two. The starter, while fixed with two hex bolts, is also supported by a third steering pin which is a very tight fit and makes the starter hard to remove and put in. Also, get a small ratchet wrench (stubby or similar) as the space is very tight.
