Originally Posted by pcube
The camber on my rear wheels is not equal, and I've been toying with the idea of getting adjustable rear lower control arms for the longest time.
That doesn't sound quite normal. It should be able to be adjusted within parameters through a normal alignment.
If you aren't lowered or heading to the track looking for more range in your alignment I do not think it's worth it.
Any suggested brands? Any cons to using the cheaper ones that cost less than $100? Any real benefits for going with the really expensive ones like Ground Control?
Cheaper ones, are made cheaper. You can see it in the construction and welds.
These are the best bang for buck IMHO
ECS Tuning. Search their website for the correct one to fit your Z4.
