Hello Shipkiller
Thank you so much for your time and pictures and to write down all the steps to do.
I got yesterday unfortunately, a bad surprise when I pressed the button to open my soft-top of my Z4 from 7/2006 and it opened just a bit and stopped.
It was moving like the engine was dying very slow, and after a feww seconds just stopped completely.
So I open it following the emergency manual operation ( very easy) and tried again to close it with the button, but its dead. so I closed it manually and now in my garage I will start in a few minutes doing the same Job as you did, removing the soft-top.
I saved all your precious information in my laptop, and I will follow step by step, I did not buy yet the parts I need, as I want see first how it looks like once all removed.
I hope you don't mind if I come to you here in case I'm blocked in any of the steps and ask you advise.
I wish my self good luck and lets see.
I will do pictures also as you say, its the best memory
Thank you for all.
