Originally Posted by WeekendWarriorz
Does anyone know if there's a difference between the e46 M3 and Z4m oil pan? Visually, they look exactly the same, and I mean exactly.
The E46 uses the part number: 11137838130 while the Z3M and Z4M share the same part number of: 11137838132
I'm not sure if there's any differences or if the last digit is changed just because of the different chassis but anyone with any information or who has any experience would be greatly appreciated! Thanks!
They are exactly the same. The Z4M uses the same front crossmember as the E46 M3, but a different dipstick / DME, so I suspect those two part numbers come with with either different dipsticks / seals or a different oil level sensor. But the pan casting itself is identical.
