P0444?
So I just finished replacing my engine, and I'm dealing with all the electrical right now. I've cleared all the DTCs the engine gave me and the car runs great now. The only issue is, I get 1 code. P0444, Emissions Evap Circuit Open. I've checked the connector to the Evap Purge Valve, and it's tight on there. I also checked the wire leads for said connector, and discovered that there's only 1 brown lead going to it. The other lead Inlet has a green insulation, showing that it came like that from factory. I've racked my brain trying to figure this one out, even going as far as replacing my wire harness, and I still get the issue. Any help?
