Originally Posted by Twixboy
You should put a drop down light & outlet from the ceiling above the hood for good measure Never know when you'll need it to see underneath the car.
I don't see one, is it in the other 2-car bay? You could connect it through the wall to a retractable air hose reel mounted in your 1-car bay above the tool chest.
I definitely thought about a drop down, but decided that an outlet at each wheel would be suitable to plug in trouble lights etc.
I'll probably pick up an LED rechargeable at some point.
The other thing I considered with a drop down is that the cord gets dragged across the paint to get under the car.
I used to have the compressor in the corner by the electrical service.
It's just stored out of the way for now.
You must have been reading my mind about locating it in the other bay and running a couple of air outlets.
I'm also looking at something similar for my shop vac.
