Originally Posted by amcp
How did you fit 255/40 in front? Any rubbing of liners?
No rubbing, not at least on street. Track remains to be seen but I’ll know by this weekend.
Keep in mind 255 tread width for one tire can be very different from another. I’m running Michelin PSS (not 4S) on a 9” rim. To answer your question though, I pulled strut tower pin & added camber washer kit to maximize negative camber with stock suspension. Fronts are probably around -2.8*.
As much as I’d like to run 265/35, pretty sure that will rub the liners.
