So here is my attempt at instructions on the led swap.first step is remove the instrument cluster. There is just one screw on the top of the housing. After that is removed you just pull it out and disconnect the plug. The plug has a latch that will push it out when you pull it.
This is what it looks like taken apart which is just 4 screws on the back and a couple of clips.
