Originally Posted by Michael9218
Molding a raised lip at this point would be difficult. I took a look at the comments on the Karbonius thread. If I understand correctly, the diameter of the oval opening is not too small. Are you using the rubber band type gasket with the plastic elbow? Has anyone tried using a silicone elbow like the one I am using? They have a lot of grip and may solve your issue. It requires the use of an E46 brake shutoff valve to change the routing from the elbow. That's what I did. I actually bought a CSL version that routes the line to the top of the plenum.
I am using the rubber band gasket but I know at least one other person took it out. Do you think leaving it in would provide a better grip?
As far as I know, everyone is using the standard elbow, but that could be worth a try.
Is part 4 on the diagram below the air shutoff valve I need? Is it a direct replacement (ie no other changes required)?
https://www.realoem.com/bmw/enUS/showparts?id=BL92-EUR-12-2002-E46-BMW-M3&diagId=11_3019
Thanks again for your help!
