Originally Posted by SHATX
Thanks for DIY - I did this for my Wifes Coupes last weekend worked perfectly. I did have a question in regards the to OP's comment in the DIY - "You won't be able to reuse the 7 8mm screw/bolts along the underside. But the bumper is actually held quite securely by the top hex screws and fenderwell expanding tabs, so the underside hardware won't be necessary." I have been searching REALoem and i cant seem to find the part that fixes the Gap underneath. Has anyone found this part number?
Glad to hear the DIY worked out for you
It's possible that the underbody pan may be a different part number for the ///M vs standard Z4, to compensate for the difference in bumper height. I don't think it's a separate piece. I opted to leave the gap though, since you can't hardly see it anyway.
