Originally Posted by WeekendWarriorz
Originally Posted by ZeD4Mr
So with this installed, it can use pump gas (91-94 AKI), different blend of e85 as well as mix of both in the tank case where I can't find e85 around?
The sensor will adjust itself where e85 only will yield the most performance?
TIA,
Correct, you can use 91 octane all the way to straight e85 with any mix in between e10-e85 and the kit will adjust. No tuning needed!
Thanks a bunch .. might give it a shot this season..
I'm still quite confused about this ethanol matter.
normally I use the highest octane possible for our engine. (Shell 91 or Chevron 94 with 0% ethanol)
but with this kit, running straight ethanol yields better performance? care to elaborate?
much thanks,
