Originally Posted by Dbaliko
I ordered a BlueBus for my E85MR without navigation. I was told that delivery would be in October. I’m a little apprehensive about the installation. But I can’t wait.
Doug
You'll access it from in the trunk. Granted I installed this on a coupe and not a convertible, but I'm sure the cables are in the same location. After removing the carpeting/trim panels, locate the amp. I removed my amp and found the cd changer wires tucked right behind it. It's literally plug and play. I secured the bluebus with double sided tape, and put everything back together. The coax cable doesn't seem to fit/work for our cars. At least it did not on mine.
