Replaced LCAs on my E85
The rear bushings were noticeably worn out. I decided to replace the lower control arms with ball joints at the same time.
Before doing this I had symptoms of a warped rotor. In changing the LCAs this warped rotor system is gone.
Thought I would pass this along as something to look at if you have similar symptoms
