09-12-2019, 08:52 PM
#12
Originally Posted by Dav3
3002 tii
I'll definitely try install again slowly. Seller helped me first time around but didn't use OEM allan key. The central bolt also is a bit threaded so maybe it wasn't fully turned after all!
When you mention 'adjusting the nuts' do you mean the protruding metal inserts on both sides of the hardtop that slip into the mounting holes next to the car pillars?
Weather stripping looks still intact. Smell is still horrible and even after airing it out it's still headache inducing.
See diagram below
Follow for latest mods
