You seem to have skipped straight to the most complex solution. People switch their amps on this and other boards seemingly regularly due to water damage and I've seen narry an indication of the problems you're having. Are you sure everything is plugged in? Have you used an ohm meter to verify you're getting power/signal in/out of the amplifier?
