Originally Posted by abashoe
bump. . .so is this really the traction setting that non-m's use b/c they have an open diff?
Originally Posted by tiltmode43
I can't help but think it differs from the M3 mode mentioned, though. My thinking is, why would BMW not enable this feature? I'm going to go with the 'intended for non-M' camp and that BMW did not need to reprogram things but rather deactivate that mode for the M models.
My guess is since our cars are so low production they didn't enable the feature. The M3 CSL has a button on the steering wheel for track mode, so they probably didn't want to add it. Many non-CSL M3 owners have enable it with coding.
The "M Track mode" does allow for a little more drift before intervening than with the DSC enabled. There are several MK60.C20 coding differences between the
M and
non-M. For instance, "DIFFERENTIAL LOCKING CONTROL" is
aktiv on a
non-M while it is
non-aktiv on the
M. I believe this is for the electronic LSD for the non-M. I attached the
M and
non-M trace file differences for review.
E85-MK60.C20-TraceDifferences.txt
From what I've been reading the biggest difference would be in wet conditions where it allows much more rear end drifting while still saving you from getting completely sideways. A wet track comes to mind. Or unfamiliar road or track until you know what/where the grip is.
Much more information can be found in
this thread over at m3forum.net where they have also enabled
M tack mode on their M3s that use the same Mk60.C20 module.
