Originally Posted by Cyclops
I was in the same predicament, running the Stoptech 380mm slotted fronts and wanted to match the rears rotor with a 996 caliper. I went with this e46 M3 ECS Tuning rotor and it worked fine. You could problably also go with the Stoptech Gas-Slotted Brake Rotors - Rear. I went with the ECS Tuning ones because the rotor is coated to prevent rust and if you're planning to use the original 996 rear pads you'd get a rust ring. You could also run the front 996 pad in the rear to avoid it but never tried it so I can't comment of the validity of the claims.
Massively appreciated. I remember that one time you, me and another guy went for a quick spin in the Halton Hills your car had matching brake disks. I was looking and all I could see was the possibility of the M5/M3 rear disk being used as Centric also makes a slotted rotor but none of them stated that it was a fit on the Z4M so I was confused. But good to know it works.
