      08-03-2020, 06:11 PM   #10
RickFLM4
RickFLM4's Avatar
Drives: M4
You may be able to find a small standby (maybe 10kw) for around $2K - just the generator, not including the slab you’ll need for it or install. Not sure. If you’re an electrician or electrical engineer, wiring yourself should be no problem. If you’re not, then this is one of those jobs where it’s probably worth hiring one.
Current: 2018 SO/SS F83 ZCP
Gone: 2015 SO/SO F82
