Low Speed Clicking Noise Help
2005 Z4 with manual transmission. Clutch, flywheel and throwout bearing were replaced about a year ago with a lightweight flywheel and clutchmaster fx250. A few months ago, I started hearing a clicking noise like the sound of playing cards going through bicycle spokes. It only happens when the car is moving forward and the clutch is engaged. It is not the typical flywheel chatter.
If you push in the clutch pedal ever so slightly, the noise stops. I originally thought the throwout bearing was going bad until I realized just resting my foot on the clutch pedal was enough to make the noise subside.
Its almost like the pedal is going too far back and is somehow causing an issue.
Ive searched everywhere and can't seem to find anyone else describing the issue. Thoughts?
