Originally Posted by ZeD4Mr
Do you have some pictures of them? Does the shoulder wings rub on the door card?
Status side mounts on which slider to VAC floor mounts?
sorry for all these questions. Seat looks really good and customizable..
This is the only picture I have at the moment. Both seats are mounted directly to the base plates. The back bolts are in the lowest slot of the side mounts and the fronts are in the highest slot. The shoulder wings barely touch the door card. I used VAC floor mounts, but the Status ones which are angled to match the slight angle of the seats would probably be better. I actually had to use the VAC side mounts opposite of what's intended (left to right and vice versa) in order to get the seats mounted inboard enough. Otherwise the shoulder wings rubbed on the door cards and the driver's seat wasn't centered behind the wheel. Hope this helps, but let me know if you'd like more detailed pictures.
