      08-03-2020, 06:15 PM   #11
Kolyan2k
Drives: 2006 S2000
Originally Posted by RickFLM4 View Post
You may be able to find a small standby (maybe 10kw) for around $2K - just the generator, not including the slab you’ll need for it or install. Not sure. If you’re an electrician or electrical engineer, wiring yourself should be no problem. If you’re not, then this is one of those jobs where it’s probably worth hiring one.
Yeah I can wire myself. And I figure gas line is not a big deal either to run a flex to it. $2k natural gas is 7.5kw Generac
I was thinking maybe leaving gasoline portable hookups alone and running new line to panel directly. And operate generator and all circuits manually.
