Originally Posted by ssummers
newbizie, can you tell us how you have it hooked up? How many channels off the amp and what are they driving? Did you install crossovers?
I have the radio grounded ti a screw behind the hu, the power for the hu is tied to an ACC fuse behind the glove cant remember which one at the moment
I then ran the amp turn on and rca cables along the passenger door jam through a hole in the back wall behind the passenger seat
the rca have a splitter so I can use all four channels using one rca cable
all four channels are being used the first two channels I have set with the apms own high pass cross-over right now those channels are running all the 3 1/2 speakers
the last two channels are running all the 6 1/2 speakers and im using. the amps low pass cross-over for thouse
all settings in the amp are turned pretty far down right now because I wasnt sure of the speakers could handle without external crossovers for the 3 1/2s pics comming tomorrow when I can break things back down
