Originally Posted by Shutterspeed
Chooot that front clearance is tight. Would have me nervous all the time. Guess you went with a 35 offset so you could cram the 275 in the front.
Its not that bad. The pics I took were not properly "gun sighting" the fender, so it looks more poked out than it is. No rubbing under compression.
Originally Posted by F360C
Your going to love this on the track/autox.... yeah the fitment can be a bit tight in the front but the increase in grip is totally worth it! I went square 275 a couple years ago and I am never going back.
Thanks, yeah I can't wait. Just need some track pads and its going to be so much fun!
Originally Posted by jns_e85
Nice! I run 255/40/17 on 17X8.5 on kosei K1 for autocross, but this is tempting to say the least. For the camber, are you running plates or a camber bolt kit?
I have the Vorshlag camber plates. I figured I'd need them in the long run, and its nice I can adjust from street and track.
I think the camber washers will bring the wheel closer to the strut, which means you'll likely need a 5mm spacer, and as you can see there's not much more room to poke out of the fender.
